Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/joomla/filesystem/path.php on line 143
Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/joomla/filesystem/path.php on line 146
Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/joomla/filesystem/path.php on line 149
Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/src/User/UserHelper.php on line 620
Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/vendor/joomla/registry/src/Format/Ini.php on line 170
Deprecated: Array and string offset access syntax with curly braces is deprecated in /data05/hheadtc/public_html/libraries/vendor/joomla/registry/src/Format/Ini.php on line 187
Meetings & Minutes
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; plgContentJw_sigpro has a deprecated constructor in /data05/hheadtc/public_html/plugins/content/jw_sigpro/jw_sigpro.php on line 19
Council Meetings
  • Monday, 6th  February   2017  7.00pm
  • Monday , 3rd  April 2017    7.00pm
  • Monday , 15th  May A.G.M   2017     6.00pm
  • Monday  , 3rd July 2017  6.00pm
  • Monday , 2nd October 2017  6.00pm
  • Monday   4th December 2017 6.00pm
Finance & General Purposes Committee
  • Monday, 6th  March   2017   7.00pm
  • Monday   5th June          2017  6.00pm
  • Monday,  4th  September  2017   6.00pm
  • Monday , 6th November  2017  6.00pm
For Information on Minutes of Past Meetings
The most recent Minutes of meetings of the Town Council are available on this website (see left) if you require old minutes they are available in the Library and the Town Hall - please ask for the Town Clerk Mr C L Everett so arrangements can be made for you to view and make copies of minutes which are not exempt under the Data Protection Act and exempt "under section 100(A)(4) of the local government act 1972 as it involve's the likely disclosure of exempt information as defined in paragraphs 7,8,9, and 10 of schedule 12A of the said act.
